Sign in to follow this
kalaiselvan
AcuSolve Log file issue
Am uable to view the results in AcuViewer, as log file is not available in my working directory and while solving the Auctail window also does not pop up....
But while i meshed the component before solving, Acutail window poped up....What may be the issue for log file missing..
i have attached the snap shot of both solving window and my working directory
Although the .inp was written, and the Acusim.cnf file updated (both at 15:47 on 13-10-2018) per the image above, it appears the job did not actually run - at least in the directory Mixing_Elbow_13Oct18 you show in the image.  Is it possible when you launched the first time that you modified the Working Directory in the launch panel?  Can you attach the Acusim.cnf file - or copy/paste the contents - from that directory you show in the image?  You may find faster assistance by contacting your local India support team.
