Dakshitha
Checking penetrations between parts
Component tickness unavailable. No templae loaded"
Hello!
I have a model with 5 components ith small initial penetrations. How can I check for them? I have already tried Tools> Penetration check
 but it gives me an error "
15 minutes ago, Dakshitha said:
@prakash
Sure. I want to remove the penetrations in this model either manual or automatic. I'm using LS Dyna. Can you please help.
newfin.k
@Dakshitha
Since it is the LS-Dyna model and it is related to the solver, I would suggest you contact Dyna support.
4 minutes ago, Prakash Pagadala said:
@Dakshitha
@Prakash
So Hypermesh cannot import the LS Dyna solver deck and remove these penetrations?
3 minutes ago, Prakash Pagadala said:
It can, but the error message may mean something else and the solver support can only clarify.
OK @Prakash Pagadala
I imported a different version of the file (attached herewith). Now it works when I open up as Hypermesh project and import LS Dyna keyword deck. However, it says " No intersections/penetrations" when I phynopen_reflect_final_sep.k sically zoom in I will clearly see penetrations. Any thoughts?
I can see a free face in comp 6!
Maybe, problem is due to precision & tolerance
Your model size is too small. If you are using length unit "meter", scale model 1 million times and use unit micrometer
Then you can check intersection easily.
@tinh
Thank you very much that actually seems to work!!! Really helpful
@tinh
Scaling up worked and now i can see the penetrations. And now I'm manually fixing some intersections/penetrations because the automatic one removes too much material sometimes.
However, while manually moving some nodes, I get an error "Nodes or elements selected do not belong to component"
How do I fix this?
Thanks in advance
DW
5 minutes ago, tinh said:
Could you explain by images?
i'll try=)
ok, example i've got penetration. but i hadn't geometry.
but i want to fix my penetration.
i have diffrent ways to do it:
but it's all for nodes and geometrical objects. i can't choose <element>.
yeah i know one way->from solid->element faces->element faces to surfaces-> you may try. but surfaces are in bad tolerance to element faces.
i think if i can choose aline nodes by mesh faces it will be great tool. in ansa i can do it and i can choose the offset distance btwn tagert elements faces and nodes.
is it clear?=)
Yes, i understand
You want to click an elem and hm will move nodes on it face (or offset at some clearance)
I will try making that
Currently, you select n1 n2 n3 on elem and that is inconvenience, don't you?
it's impossible if you should align 1000 nodes and have 100 elements for example=)
i use this tool when i have a geometry.
1 hour ago, Dakshitha said:
@tinh
Thank you very very much. It works.
Do you know how I can make multiple copies of a component using translate? And then check for duplicate nodes and merge?
Sorry for the continuous trouble.
Invoke dropdown menu Tools>Transformation
And Shift+F3 to merge nodes
OK. so i will make a script with a loop that project node to the closest elem
Mrt likes this
