niwi
Shear stress size in tensor plot
I just want to show the shear stress of specific elements in a tensor plot. For the sake of better visualisation I want these arrows to be bigger than the corresponding elements.
I can create the tensor plot for shear stress in the XY plane without a problem. The problem is I can't seem to scale the shear stress since it seems to be limited to the element size. Even if I use tcl and the "poITensorCtrl SetShearComponentScale " command, I can only use values between 0 and 1. Is it possible to circumvent this problem?
Thanks in advance!
Did you test this? Because that is exactly what I tried before and it didn't work then. Doesn't work now either.
In your example you selected Principal Stresses. I want to use the shear stress. So the tensor format needs to be changed and only XY (for example) should be ticked.
Thank you
On 10/22/2018 at 2:21 PM, niwi said:
Thank you
1
How about these settings, instead of arrows try CrowsFoot. I will check why the arrows are not displayed.
