vipin
Select elements from a set of nodes
Hi all,
Is there any direct api to select elements from a set of nodes?( For example in the image i need the highlighted elements, dont need the adjacent elements to be selected.)
I tried *findmark and *createmark which are selecting the nearby elements too.
Hi Vipin
You can ignore adjacent elems
*createmark nodes 1 {*}$NodeList
*createmark elems 1 "by node" {*}[hm_getmark nodes 1]
*createmark elems 1 reverse
*appendmark elems 1 "by adjacent"
Pandurang likes this
Another solution you can try is the following:
hm_createmark nodes 1 "by id only" $NodeList;
hm_createmark nodes 1 advanced reverse;
hm_createmark elems 1 "by nodes" [hm_getmark nodes 1];
hm_getmark elems 1;
Just another way to handle this....
*createmarkpanel nodes 1 "Select nodes to which the attached elements have to be determined"
eval "*createmark elems 1 \"by nodes\" [hm_getmark nodes 1]"
eval "*createmark nodes 2 \"by elems\" [hm_getmark elems 1]"
*marknotintersection nodes 1 nodes 2
eval "*createmark elems 2 \"by nodes\" [hm_getmark nodes 1]"
*markdifference elems 1 elems 2
set attached_elem_list [hm_getmark elems 1]
tinh, vipin and Pandurang like this
