Adeel Qadir
How to renumber any sheet metal quadrant nodes in sequence
I am calculating initial numbers of clamps and locator for sheet metal in primary plane. i am using maximum deformation method. I am confused, after renumbering I generate F06 file and see all nodes are given in series from 1 - 4914. but on plate renumbering is in different order. How can i check nodes with max.deformation in different quadrants?
IN attached file, i want to renumber nodes in given window; from 1 to 50 e.g.
