Sign in to follow this
Teja
Reaction force of bolt
Hi @Prakash Pagadala
I am working on project in which i need to find stress generated in bolt. Bolt is between the cover and housing. When bolting torque is applied I want to find stress generated in bolt.
How to solve this problem
Thanks in advance.
Hi Teja,
You can either do a pretension analysis and output Pretension bolt force. The PRETBOLT command can be used in the I/O Options or Subcase Information sections to request output of pretension force/adjustment values in the pretension bolts for all pretensioning and pretensioned subcases.
Or
use GPFORCE to output if you are just running a linear static analysis.
