mansin
Material orientation of ply
1. Is the material orientation of each ply the same? I assigned different material orientations to each ply, but I cannot get the expected material orientations.
2. How to assign material orientation to elements with ply (fiber) direction? I try to assign the material orientation to plies with the cooridinate systems each ply used in drapping operations. But I found the obtained material orientation is not coincident with the ply direction. The attached pictures  are the results of this test (for example, the directions in face A). I want to get the same directions, but I don't know how to do.
image.png.b68aff213f702b6aa15ab1479e28c5f8.pngimage.png.51620262eea18963bad1b2f22c26c181.png
Material_Direction_of_Ply.hm
Hi mansin,
I see that you have given same orientation for both the plies. Please check.
Thank you
Hi @mansin
Is there a reason for having two systems?
You can align material with one system and have different angles on two plies. Since the difference between the two plies is 120, you can have one ply with 0 and the other with 120
Hi, Prakash Pagadala
I cannot assign different material orientations to each ply element, although I set the ply angle of the two plies in one coordinate system. Are the material orientations in each ply of composite material's model the same?
Many Thanks.
