LOKESH KATARI
Model Reduction Methods
4 minutes ago, LOKESH KATARI said:
Can we see that how much DOF it is decreased in hypermesh ?
Hi @LOKESH KATARI Can you please explain what do you mean by DOF decreased?
Also, please use appropriate forum threads to post your questions so that it will be addressed soon.
@LOKESH KATARI
DOFs are depended on element numbers/types.
quad shell first order has 4 points and 6 dofs on every point=24 DOFs.
If you create full vehicle model which contains 100.000 points (only shell elements and beams) you will have 6*100.000 DOFs
if you separete chassis from full model and it will include only 50.000 points you can estimate your reduction coefficient=)
Usually, total degrees of freedom will be written in the .out file. You can use remove the constrain dofs from the total... I guess this will help?
