Chethan Y C
Internal Programming error in Optistruct
I am get the below error while simulating in Optistruct, This is the first time I am getting this error and I am not able to figure it out, Kindly give me a solution. I tried all the iterations regarding this issue from altair forum , I am using 2017 version, cleared all the temporary files, element count =1166221, Hexa elements, Using NLSTAT with material and contact non linearity and pretension loading.
 Starting load increment 1 Current increment 5.0000E-002
  Subcase         1  Load step:  5.0000E-02
               Nonlinear Error Measures  Gap and Contact Element Status  Maximum
 Iter Avg. U    EUI      EPI      EWI    Open Closed Stick Slip Frozen  Plststrn
 *** INTERNAL PROGRAMMING ERROR ***
   in file "newahashc.c", at location # 993.
   HSAS READ ERROR: 1538844784
 OptiStruct error termination report printed to file
 "20181102_Yoke_IMS_PI_Nineth_Model_64bit.stat".
 *** WARNING # 8112
 Failed deleting file
 "D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/20181102_Yoke_IMS_PI_Nineth_M_1268_05_has.rs~".
 There were 1 WARNING(s) reported during the run.
Chethan
 **                         OptiStruct 2017.0                          **
 **                  Design and Optimization Software                  **
 **                   from Altair Engineering, Inc.                    **
 **           Windows 7 Workstation  SP1 (Build 7601)  CAE04           **
 **         36 CPU:  Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz         **
 **                        CPU speed  2300 MHz                         **
 **                   120461 MB RAM,  261985 MB swap                   **
 ** Build tag: 0846091_9433170_Ce64RBW8UH14M:124987-000  4000020004000 **
 **  COPYRIGHT (C) 1996-2016                 Altair Engineering, Inc.  **
 ** All Rights Reserved.  Copyright notice does not imply publication. **
 **         Contains trade secrets of Altair Engineering, Inc.         **
 ** Decompilation or disassembly of this software strictly prohibited. **
 *** OptiStruct defaults set from:
   install config file: C:/Program Files/Altair/2017/hwsolvers/optistruct.cfg.
 NOTE # 9199
 MSGLMT=STRICT is active, all messages will be printed.
 You can suppress some less important warning messages by use of
  MSGLMT=BRIEF or UNREF (in config file or in the input data).
 3 PARAM(s) were set:
    CHECKEL,NO
    I64SLV,YES
    LGDISP,1
 *** INFORMATION # 3071
 SPOINT # 1227083 is automatically generated for PRETENS # 4.
 *** INFORMATION # 4736
 The realization of node-to-surface contact at large displacements is not
 exactly the same as in small displacement (NLSTAT) analysis. No internal
 CGAP/CGAPG elements are created in the large displacement case.
 *** INFORMATION # 4739
 The structure of surface-to-surface contact element is quite different than
 that of node-to-surface contact element. No internal CGAP/CGAPG elements are
 created for surface-to-surface contact.
 *** INFORMATION # 815
 The total number of rigid elements, whose rotational dependent d.o.f.
 are removed because there is no need to constrain those d.o.f., is 2.
 NOTE # 2715
 Solver with 64 bit integer is activated.
 *** INFORMATION # 3433
 MUMPS solver is used by default for nonlinear analysis at subcase 1.
OPTIMIZATION FILE AND PARAMETER INFORMATION :
  FEM model file               : 20181102_Yoke_IMS_PI_Nineth_Model_64bit.fem
  Output files prefix          : 20181102_Yoke_IMS_PI_Nineth_Model_64bit
  Model read from files:
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :   1127128
  Total # of Elements Excluding Contact:   1166219
  Total # of N2S Contact Elements      :     52381 (no internally created CGAPG)
  Total # of S2S Contact Elements      :     78916 (no internally created CGAPG)
  Total # of Rigid Elements            :         2
  Total # of Rigid Element Constraints :      9378
  Total # of Degrees of Freedom        :   3390753
  (Structural)
  Total # of Non-zero Stiffness Terms  : 138268705
  Total # of Pretension sections       :         1
  Element Type Information
   CHEXA    Elements   :   961154
   CTETRA   Elements   :   187048
   CPENTA   Elements   :     5491
   CPYRA    Elements   :    12526
  Load and Boundary Information
   FORCE Sets        :         2
   SPC   Sets        :         1
   MPC   Sets        :         2
  Material and Property Information
   PSOLID Cards      :         5
   PCONT  Cards      :         1
   MAT1   Cards      :         3
   MATS1  Cards      :         2
OPTIMIZATION PROBLEM PARAMETERS :
 NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND  : ANALYSIS ONLY
   Static Subcase Summary :
   Subcase ID    SPC ID   FORCE ID
        1           11            0
   Run Type                        :   Analysis Only (No design elements)
   Run at location                 : D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/
   Scratch file directory          : D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/
                                     Free space:   285.686 GB
   Number of CPU processors        :         32
MEMORY ESTIMATION INFORMATION :
 Solver Type is:  Sparse-Matrix Solver
                  Direct Method
 Current Memory (RAM)                                    :   19617 MB
 (Note: MUMPS Solver Allocates Memory Separately.)
 Estimated Minimum Memory (RAM) for Minimum Core Solution:   51571 MB
 Recommended Memory (RAM) for Minimum Core Solution      :   51617 MB
 Estimated Minimum Memory (RAM) for Out of Core Solution :   53175 MB
 Recommended Memory (RAM) for Out of Core Solution       :   54848 MB
 Recommended Memory (RAM) for In-Core Solution           :  196252 MB
 (Note: Memory for MUMPS Solver is Included in Estimation.)
 (Note: Minimum Core Solution Process is Activated.)
DISK SPACE ESTIMATION INFORMATION :
 Estimated Disk Space for Output Data Files              :     642 MB
 Estimated Scratch Disk Space for In-Core Solution       :    3559 MB
 Estimated Scratch Disk Space for Out of Core Solution   :    3559 MB
 Estimated Scratch Disk Space for Minimum Core Solution  :    6790 MB
BEGINNING ANALYSIS SOLUTION ....
ANALYSIS RESULTS :
ITERATION   0
 List of Auto-SPC d.o.f.s for loadcase   1
 Total number of Auto-SPC d.o.f.s = 9378
     Grid No.         Component
                     937381             4 5 6
                     937382             4 5 6
                     937383             4 5 6
                     937384             4 5 6
                     937385             4 5 6
                     937386             4 5 6
                     937387             4 5 6
                     937388             4 5 6
                     937389             4 5 6
                     937390             4 5 6
                     937391             4 5 6
                     937392             4 5 6
                     937393             4 5 6
                     937394             4 5 6
                     937395             4 5 6
                     937396             4 5 6
                     937397             4 5 6
                     937398             4 5 6
                     937399             4 5 6
                     937400             4 5 6
                     937401             4 5 6
                     937402             4 5 6
                     937403             4 5 6
                     937404             4 5 6
                     937405             4 5 6
                     937406             4 5 6
                     937407             4 5 6
                     937408             4 5 6
                     937409             4 5 6
                     937410             4 5 6
                     937411             4 5 6
                     937412             4 5 6
                     937413             4 5 6
                     937414             4 5 6
 Because of PARAM, PRGPST, 100, Auto-SPC printing is limited to 100 dofs.
        Nonlinear  iteration  summary for    Subcase        1
 *** WARNING # 8112
try to solve reduced model/part of model.
it's difficult to search mistake in large model.
Hi @Chethan Y C
On 11/12/2018 at 2:20 PM, Chethan Y C said:
  • Sorry, i am not supposed to share the model.
  • The model has hybrid meshing (Hexa, pyramid,tet), does it cause a problem?
Can you share the .out at least so that I can check with developers?
