Isshaan Arora
Error Window
AcuConsole requires the volumes to be meshed (whether fluid or solid) need to be represented in the CAD as solid bodies.  If your CAD is only surfaces, then you need to turn on (check) the option for 'Fill Volumes' in the initial CAD import window.  With that enabled, any volume completely closed by surfaces that doesn't have a 'solid' will then be created as a 'solid' body to be meshed.
