Sign in to follow this
Ekaterina
Topology optimization results interpretation
Hi!
I have a question connected with topology optimization results. I optimized solid Design Space, but as the result I got shell structure  when I choosen equal values on the result panel.
1) Could you please explain why is this shell and how Optistruct calculates mass in .out file in this case:  mass of solid or shell?
2) What is the physical difference between element densities as 0.8 instead of 1?
Best regards
Hi @Ekaterina
Can you try with a different constraint for optimization?
Composite failure response will not work because the design variable is different
