Sign in to follow this
jacobier
Smooth line or skin surface not working
Is this a bug of Hypermesh? Or some setting goes wrong? The smooth line and skin surface functions suddenly work improperly. They only capture two points of the node list in the smooth line case. And it only generates a surface cover some part of the line I used to make skin surface.  bug1.bmp
Hi @jacobier
are you sure the smooth lines are not segmented? When picking line list on skin panel is the whole segment highlighted? If not then you can combine segments by Geom>line edit>combine
I recreated the problem on my end and it HyperWorks B) (version 2017.2.4).
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
