Sign in to follow this
VAL1
press model analysis by Non linear quisi-static
I'd like to analysis using distorted model (attached file).
make this model transform to plane like pressed,
and want to calculate how much force is applied.
I set contact surface use another two plane object upper side and lower side,
but this analysis didn't convergent.
How should I do?
(this attached image is exaggeration. actual distortion is 0.5mm)
HI,
Now I changed the contact from PCONT to SLIDE and with S2S and I see the progress. But the results are yet to come out.
FINITE sliding searches contact for every load increment but with continuous sliding, the search is conducted for every iteration. CONSLI provides better convergence when large sliding is present in the model.
Hi @VAL1
The model didn't converge at my end and I see a lot of element distortion at the end(till 99% converged). I will check if this has anything to do with the material.
There are several tutorial available in RADIOSS for example RD-T: 3595 Three Point Bending with HyperMesh
Hello , Prakash san
Thank you for information , I try to use Radioss with RD-T: 3595.
by the way If possible, could you give me the 99% converged result?
And I couldn't download RD-T: 3595 sample from website, Could you share it?
