Sign in to follow this
anderlanza
Radioss problem
Hi Ivan,
First of all, thank you for the respond .
In the image below I was putting  the honeycomb material in "espuma" and " honey" and it was a BRICK, in which way I can change number of nodes?
As I have seen in the pdf that you have send me, if you have  BRICK the only way to have compatibility is by having 8 nodes so what can i do?
The problem is you have SHELL3N (triangle 2D elements) in component which were assigned law 28 material.
Isolate the components assigned to  law 28 material and mask solid elements, then delete the shell elements.
anderlanza likes this
