yogeshchandra
unable to generate h3d file
Hi @yogeshchandra
No modes exist between your frequency range and that is the reason no h3d file is generated.
Please request modes with just ND on EIGRL and check if that helps.
@yogeshchandra
13 hours ago, yogeshchandra said:
how can i establish connection between members , if they are not connected and comes out from geometry during modal analysis ?
It depends on how complex the problem is. You can connect elements nodally by equivalencing. If there is no node within the tolerance, then you may have to trim the element and make room for a node and connect
