Sign in to follow this
ANILMANNE
Capture image with user orientation requirement ( node information based )
Hello All,
     i'm trying to capture image (node id>attached attached elements > for loop to take care of adjacent elements).
Issue : capture image should be in isometric view with center reference as node (current script orientation issue).
Please help me thanks in advance.
script:
 set node(id) "
169122
275259
    foreach nodeID $node(id) {
      *displaycollectorwithfilter components "none" "" 1 0
      *createmark nodes 1 $nodeID
      *nodemarkaddtempmark 1
      *findmark nodes 1 257 1 elements 0 2
      for { set a 1}  {$a < 60} {incr a} {
      *retainmarkselections 1
      *createmark elements 1 "displayed"
      *findmark elements 1 1 0 elements 0 2
   *window 0 0 0 0 0
  *jpegfile
  *nodecleartempmark
      Rotation may help (each rotation {till 180 deg} measure node position,  distance with respect to global X,Y,Z  and  nearest distance to global) working on it.
Anil.
