francesco aloschi 0 Report post Posted November 16, 2018 Hello i'm having problems with rb2 connections i need to join different large surafaces and i wish to know if there is a tecnique that allow me to select different numbers of nodes and connect it to o the other surface. i will post an image to explain it. i wish to create a list of nodes and connect it to the other list Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted November 17, 2018 If mesh sizes are same, 2 node lists should be same Quote Share this post Link to post Share on other sites
Mrt 12 Report post Posted November 17, 2018 do you want connect "node to node"? or "node to node set"? Quote Share this post Link to post Share on other sites
Pranav Hari 59 Report post Posted November 19, 2018 Hi francesco aloschi This video on RBE2 connection may help you.. https://altairuniversity.com/learning-library/hypermesh-1d-rigids-bars-and-beams/ Quote Share this post Link to post Share on other sites
francesco aloschi 0 Report post Posted November 19, 2018 i wish to coonect" node to node" each element. But i'm not able to create a node list . how can i do? yes two componets have the same mesh size. Quote Share this post Link to post Share on other sites
Guest Report post Posted November 19, 2018 Hi, Try this, Go to 1D>> COnnectors>> Spot. Change the weld type to Rigid, select the nodes, components to connect and click create. Quote Share this post Link to post Share on other sites
francesco aloschi 0 Report post Posted November 19, 2018 i followed this procedure but it doesnt's work. I select the nodes and when i press create everything disappear. Quote Share this post Link to post Share on other sites
Guest Report post Posted November 19, 2018 Maybe this video will help? The distance between two plates is 5 units and used rigid lo connect. RBE2.wmv Quote Share this post Link to post Share on other sites
francesco aloschi 0 Report post Posted November 19, 2018 thank you for your help but i didn't solve this problem i need to link nodes from 1 to 6 with node from 8 to 13 that are in the same middle surface but they are two different components. Quote Share this post Link to post Share on other sites
Guest Report post Posted November 19, 2018 @francesco aloschi Okay. Let me check if there is a way to do this. Quote Share this post Link to post Share on other sites
Guest Report post Posted November 19, 2018 If it is only those nodes you can use rigid, select the nodes and create the RBE2 Quote Share this post Link to post Share on other sites
