VAL1
2 contact in succession (optistruct)
I try to analyze press fit with 2 contact object like attached file.
this object has 2 contact surface and there are overlaps.
How to set the condition to analyze in succession?
Eg, first contact 1 is calculated and after the calculation,  contact 2 is calculated
Thank you,
But what is the difference between MORIENT:OVERLAP and  MORIENT:blank?
I could do press fit analysis with MORIENT:blank, in this case the overlaps are got rid of at the same time.
I'd like to get rid of overlap in order...
6 minutes ago, naoki said:
Thank you,
For "MORIENT: Blank" , it takes default which is open gap i.e. contact interface is open. OVERLAP condition says the slave and master body overlaps.
Rahul R likes this
