NVH GURU
How to launch Batch mode in HV TRANS. ?
Hello all,
How you doing. ? its been a long time since i have asked my question.
MY QUESTION:
i have .odb files of size 2.7GB , and i am having 16 cases. now i need to send those result files to France.
so i planned to use HV TRANS to reduce the ouput file size ( by keeping only the output which i want).
i can do that by one by one. but you guys know importing this much size files takes lot of time.
so i planned to use the HV TRANS in batch mode. ( some where i studied that batch mode is available ), but i dont how to use it..
1. Please explain how to import all 16 cases at once in HV TRANS and how to proceed forward in batch mode ?
2. i need to import all 16 files at the same time and i need 16 H3D files.i think this is possible.  your opinion pls ?
My project delivery date is near by.. so quick suggestion are really appreciated.'
thank you..
Guruganesh
NVH
Hello Mr.@Prakash Pagadala
thanks a lot for the quick reply.
i read the pdf..
but the probem is my system Altair product are installed locally. we are accessing through a server.
so because of that i cant found the HV TRANS  in located in given link : \\Altair\hw14.0\io\result_readers\bin\win64
1. so to perform this option , does the altair products need to be installed in local.
2. in pdf they said run Hv trans.exe. should i need to open the cmd window in the working folder and lauch the hv trans. or in default just open default cmd promp and launch it.
awaiting for your reply ,
thank you
Hello @Prakash Pagadala
i tried in a system in which the altair products installed locally.
in that system also , i can run the command only in that installation folder only ( c - drive).. ( For example ---   hvtrans -a testfile ).  but i dont have permission to copy the files.
so i copied that HV trans file to my working folder and tried to run. it asked so many setup files. i copied all the files and then also i cant run .. showing some error.
please suggest me , how to run that command
thank you
Hi @NVH GURU
I will check with the experts on how to run HV trans on a local machine.
Can you share the error message which you have got when you copied to your local directory?
 4 methods i have tried . the error you're asking is for the fourth method.
please refer all the four methods.
01_when launch in work folder
02_used command prompt in installation folder and given the path location to my working folder
03_if i use the command in installation folder , its opening normal HV trans window. ( even though if it open , its not possible to open muliple files)
04_this Error got after copying the setup files ( necessary files).
I need to solve this issue very quick , please share your ideas.
thank you in advance.
No update so far. If you can share your details through a message, I will request one of our technical specialists to guide you through hotline support.
