Pandurang
Flange hex Mesh automation...
Dear All,
is it possible to automate hex mesh for Flange (see ref Image attached) with washer around holes (holes may more than 2) .
Any idea...Please Suggest...
@tinh
Regards
PD
Hi Tinh
hm_holedetectioninit
*createmarkpanel surfs 1 "Please select surface"
hm_holedetectionsetentities surfs 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
set n [hm_holedetectiongetnumberofholes]
I using these commmands to find surface holes...but Not getting single hole through this..am i doing wrong?
On 11/22/2018 at 3:12 PM, tinh said:
yes,
1) find holes
2) washer split holes
3) automesh upper faces
4) drag down to generate hexas
First thanks for help....
Up to second point is done ...Now how can automesh the face..?
Means how to use  *set_meshedgeparams and *set_meshfaceparams....
