sumit426
Taylor welded sheet metal forming
Dear All,
I have a project where a draw operation is required for the 2 sheets joined withTaylor welded/TIG welding process.  Can you please tell me the procedure for hyperform simulation?
please go through Hyperform videos:
https://www.google.si/search?q=hyperform&tbm=vid&ei=Bzv4W5WdGOeDrwTV0o6gBg&start=0&sa=N&ved=0ahUKEwjVvNaVh-veAhXnwYsKHVWpA2Q4ChDy0wMIXA&biw=1689&bih=845&dpr=1.1
Although TWBs is not demonstrated you can get an overview of how forming simulations are done in general.
Attached is tutorial HF-1040: Laser Weld
Manufacturing_Solutions_Tutorials.pdf
1Step_laser_weld.hf
1Step_Laser_weld_FLC_curve.csv
It might be that some guy named Taylor welded sheets, but they are more commonly known as tailor welded blanks :D
