zhoutaozju
Error Code:9; Feature not Found
   My WinProp is equipped by student edition license. Recently, I tried to run the sample project of WinProp which is located in "..\Altair\2018-edu\feko\api\winprop\compiler.cpp".   Unfortunately, it seems there is some thing wrong with my licence (as is shown in the following figure).
I am able to run WinProp in user interface normally which indicates the correctness of my license. I did check my Ethernet ID which was the same as that in my licence. And I am sure the filename of my license is "altair_lic.dat" rather than "altair_lic.dat.dat".
I also tried it on my friend's computer which is equipped by a student edition license, too. Similarly, his user interface worked normally but he met the same error as mine when running the sample program of WinProp API.
I notice that the alert claims that some necessary features are missing in my license. And I didn't find those features in my license indeed . So I think maybe it is the matter of my license edition rather than the matter of my Ethernet ID. Shall I upgrade my license?
By the way, my platform is VS2015. Shall I do any configuration before running the program?
Thanks for your help!
Regards.
It is indeed a limitation of your license. The student license enables you to run WinProp through the Graphical User Interface (GUI), but not through the API. To run WinProp through the API, a regular license is needed.
