mrtimwinkler
Composite Fiberorientation
i like to simulate a tensile test of an UD FRP in HyperCrash.
Therefore i use BRICK elements, the material LAW25 and the propterty TYPE6.
To model the 90° fiber direction (perpendicular to the velocity boundary condition) i made a skew (to see in the bottom right corner of the pictures 2 and 3) and used it in the property type 6 to define the orthotropic direction (to see in picture 1).
Now the RST vectors (what are these?) dont have the right and uniform orientation (to see in the pictures 2 and 3)
How do i define a 90° fiber direction?
Thank you very much!
Tim
like I said in the other topic about RST vectors- it is a local element orientation system. I do not know if it can be edited in Hypercrash. In Hypermesh it is simple for 2D: 2D>composites>material orientation. I do not know how it is done for 3D.
But I think the skew in type 6 property overrides local element orientation. There was a similar discussion:
I suggest setting up a simplified model with strong anisotropy to check the effects of different orientations.
