Sign in to follow this
mkress
Deleting a Variable / Application Error
Hey guys,
I'm looking for a command to close or delete a variable totally. I got the problem that when I'm trying to run my script for the second time this error is occuring:
This is the file in which the error is occuring: temp_in_fem.tcl
Before starting this script the sample.scv file is created in this file: create_force_constraints.tcl
I guess the variable is still saved somewhere in hypermesh and thus it can be deleted totally. I'm looking forward to your ideas.
Kind regards
Michael
Hello thin, thank you for your reply,
the variable is a .csv file which i created with the script "create_force_constraints.tcl ". After that i would like to open the file with the script " temp_in_fem.tcl ". Both scripts starts with a button in the utility menu.
Is it possible that the error related to the memory of Hypermesh? Perhaps the scripts are still running?
I want to close the script " temp_in_fem.tcl " with the command "exit" at the end of the script. Perhaps i should use an other command?
Kind regards
Michael
Hey tinh,
here is the codes you asked for:
set path ""
    set name ""
    set temp ""
set infor ""
set infor [open C:/Users/Simon/Documents/path.txt r]
        #Startinformationen einlesen
    while {[gets $infor line]!=-1} {
        #Variable zeilenweise auslesen
        incr z
        #Zeilenzahl
            if {$z==1} {set path $line}
            if {$z==2} {set temp $line}
            if {$z==3} {set name $line}
        #Informationen der Zeile 1+2 in Variable schreiben
    #Programmteil 2: Umrechnung der Knotenspannung
    set data ""
    set data [open $path/sample.csv r]
        #Knotenspannung einlesen
        while {[gets $data lines] >=0} {
        #Loop für jede Zeile
            if {$lines==""} {break}
        #Wenn Zeile leer ist, abbruch
                incr i
        #Loopzähler
                    if {$i>=1} {
        #Ab Zeile 2 in Variable schreiben
                        set fields [split $lines ","]
                        lassign $fields field1 field2
        #Zeile an Komma trennen, die zwei erstellten Werte in Variablen schreiben
                            if {![regexp {N/A} $field2]}     {
        #Wenn in Feld 2 {N/A} steht wird die Zeile nicht in Variable geschrieben
                                if {$field2>=$temp} {
        #Nur wenn Spannung größer als Referenztemperatur, einschreiben
                                set dif_temp [expr $field2 - $temp]
        #Temperatur differenz berechnen
                set a "TEMP"
                set b 3
        #Parameter die zusätzlich eingeschrieben werden
                set formatStr {%0s%12s%8s%8s}
        #Zeichenabstand der Variablen definieren (1s = ein Lehrzeichen)
                append xxx "[format $formatStr $a $b $field1 [format "%.1f" $dif_temp]]\n"
        #write everything in a variable
            close $data
    #Programmteil 3: Suchen der Einfügezeile in der .fem Datei
        set fp ""
        set fp [open $path/$name r]
        set fem_file [read $fp]
        close $fp
        #öffnen der .fem Datei
            set a 0
            set b 0
            set e 0
        #setze Variablen =0
                set daten [split $fem_file "\n"]
                foreach line_pos $daten {
        #loop, jede Zeile abfragen
                if {![regexp {SPC} $line_pos] || ![regexp {1} $line_pos]} {incr a} else {set b $a}
                if {[regexp {SPC} $line_pos] && [regexp {1} $line_pos]} {incr e}
        #Logik, für das Finden der individuelle Einfügezeile
                set num ""
                set num [expr $b + $e +1]
        #Zeilennummer
    #Programmteil 4: Einschreiben in die .fem Datei
        set daten ""
        set daten [open $path/$name r]
            set y 0
        #Setze Variable 0
                while {[gets $daten zeile] >=0} {
        #Loop einlesen
                    incr y
        #Loopzähler
                        if {$y<=100} {
                                append zzz "$zeile\n"
        #.fem Datei bis Zeile 100 in Variable schreiben
                            if {$y==$num} {
                                append zzz "$xxx\n"
        #Temperaturen in Variable schreiben
                        if {$y>100} {
        #.fem Datei ab Zeile 101 in Variable schreiben
                            if {![regexp {TEMP} $zeile] || ![regexp {3} $zeile]} {
        #wenn bereits Temperaturen in der .fem Datei stehen, diese nicht in die Variable schreiben
        #einschreiben der .fem Zeilen
    #Programmteil 5: Outfile erzeugen / Programm schließen
        set outfile [open $path/$name w]
        puts $outfile $zzz
        close $outfile
        #outfile erzeugen und Variable einfügen
        catch {unset temp outfile}
        #zur sicherheit ????????
        exit
        #Programm schließen
Kind regards,
Simon
temp_in_fem.tcl
