Meerten
S-parameters phased array
I have a 4by4 symmetrical phased array, but something strange is happening with my S-parameters. Because my array is symmetrical, the following should approximately be the same: S11=S1616, S21 = S1516 etc.
However, when I look in my .s16p file, S1516 is -180 degrees shifted in phase with respect to S21. What causes this shift? Thanks in advance!
MWA_tile_sur_v3.cfx
MWA_tile_sur_v3.cfx.bak
MWA_tile_sur_v3.fek
MWA_tile_sur_v3.opt
MWA_tile_sur_v3.out
MWA_tile_sur_v3.pfg
MWA_tile_sur_v3.pre
MWA_tile_sur_v3.str
MWA_tile_sur_v3_SParameter1.s16p
MWA_tile_sur_v3.bof
MWA_tile_sur_v3.cfm
MWA_tile_sur_v3.cfs
Hello @Meerten
We double checked your results, both in the .bof file and the .s16p file that you exported, but were unable to reproduce the problem that you described. In our case the phase of S21 and S1516 was almost identical. Can you please double check on your side, or attaching a screenshot?
