Gopi T
How to create component/properties using TCL script?
I am begineer to TCL scripting!
I want to create components with the name component_t0:5 to component_2.0 with 0.1 increment from 0.5 to 2.0 using for loop .
Can anyone help me in this?
When I create properties often I have some problems with the IDs. (on LS-Dyna profile)
I get ID conflict even though the ID is unique in the model.
What can I do to fix this?
Thanks,
Jefferson Vieira
On 11/27/2018 at 6:00 PM, tinh said:
for {set i 5} {$i<=20} {incr i} {
    *collectorcreateonly comps comp_t[expr 0.1*$i] "" 11
Hello Sir,
Thanks for your information.
I have created properties using above code. But I want to update thickness value according to the pro/comp name
Example:
thickness_t2.1  #comp name
thickness_t2.1. #prop name --- in this i want to update thickness according to the name i.e 2.1 and card image also(PSHELL) in the same loop.
Thank you,
You can use a logic similar to below:
set str_compname "thickness_t2.1"
set thickness [string trimleft [lindex [split $str_compname _] end] t]
set str_prop [hm_getvalue comps name=$str_compname dataname=property.name]
*setvalue prop name=$str_prop  95=$thickness; #95 is thickness dataname in Nastran user profile
vipin likes this
16 hours ago, Livil Lyle said:
Thank you
