Brenna liu
Hyperview fail to open files
I re-run Optistruct and goes to hyperview, I get the error below. Nothing loaded. See picture 1.
Interesting, I un-check the load results only check the Load model, I can load the model. See picture 2
Then I un-check the Load model only check the Load results, I can get result.
But I can not load them together.
Capture.thumb.PNG.2d7baa9c75c1673686b8d83653a32b3a.PNG663795033_Capture1.thumb.PNG.53928fb6b54b7e69497b2c8406ddcb64.PNG1326566633_Capture2.thumb.PNG.bf29533c91d3745c10ae429e5e4ec1c4.PNGSee picture 3.
Normally there is no result math operations, if you are loading model and result files only.
Do you have created result math within the expression builder? If yes, post it please.
Result math operations are saved also in the *.mvw files, including the result math template.
If you are using sessions, then you can search for Standard in mvw and replace it by Advanced.
Otherwise it will not work with sessions.
Best Regards,
Mario
