jacobier
Remove 3D elements free edges
I know someone has asked this topic before. However, all the solution I found did not work on my case.
I used "edges" to find the free edges between two hex elements.  I have tried to remove it by " equivalence " and by deleting the elements and creating them again. When I checked the nodes on the two hex elements. I found that there is one shared node has two ID numbers. So I also tried to replace one ID with another ID. None all these methods worked.
Please help me.
Thank you very much!
Ch_Inner_v11.6.hm
Hello jacobier,
The left of the two masked (hidden) elements (yellow, Reissner's membrane) is at fault.
It's a degenerate hexa element, rather than a penta. Therefore, at this point, the nodes can not become equivalence.
Best Regards,
Mario
jacobier likes this
