Ciro.Alosa
How to compute torque on a brushless with sensor
To compute the torque in Flux using a sensor you need to create a sensor. To do it:
  • In parameter/quantity j, create a new sensor
  • Type of sensor: predefined, magnetic torque
  • Rotation axis:
    • Direction: parallel to oz
    • Pivot point (0,0)
  • Computation domain: select a face region.
Other way to compute the torque is to draw a 2D curve of torque. To do it:
  • Curve
  • 2D curve (I/O parameter) >> new >> mechanical set >> select electromagnetic torque
To use this data in Simulink, you can export this curve as txt file. In you Simulink model you can use a look up table to read this txt file.
Hope this will help.
Best regards.
RAVITEJA_028 likes this
