Toon
Frequency response analyisis
Hi
I am performing a modal frequency response analysis with OptiStruct. The model I have gives the displacement as output. However, I am interested in the acceleration as output. I tried obtaining this by checking the acceleration box under load steps => load case => subcase options output, but I could not access the acceleration result when in hyperview. Am I missing something? I can calculate the acceleration from the displacements but I feel like I should be able to get the acceleration results directly from the model.
Thx
Hi Premanand,
Thank you for your reply. I will try the solution you proposed.
Additionally, I assume I should also check the acceleration box under the subcase options of the load case, or should I leave it on displacement?
Thank you
