Roy Duan
Is there any example about midsurface extract and repair script for complex structure?
Hi all,
For complex thin structure, we often cannot get a complete midsurface. That is to say, the surface  is  discontinuity or intersection.  Is there any example about midsurface extract and repair script for complex structure? Thank you.
Roy
On 12/8/2018 at 6:35 AM, RahulJ said:
Try to search resource library in Altair site. It have nice video for advance mid surfacing techniques and tools.
Hi RahulJ,
Could you show me some URL link? I have not found any resource. Thank you.
Roy
@Roy Duan
I recommend to use the midmesh panel in 2D page.
It just select a component, and input mesh size (2.0), and check the "flatten connections" and hit the create button.
You can get the below pictured result using direct midmesh panel.
Please try it:-)
Thanks,
Imoto
On 12/13/2018 at 6:26 PM, Imoto said:
@Roy Duan
Please try it:-)
Thanks,
Imoto
Hi lmoto,
I have tried the method you mentioned. There are also some problems. Is there any other good method which can be used to this model? The least time is needed along with correct midmesh.
In addition, is there any detail explanation documents about midmesh panel?
Roy
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
