Pandurang
Connector automation for 3D holes in Flanges
Hello All,
I have 2 flanges having co-linear holes...i want to create rbe2 in holes and connect these rbe2 for  co linear holes with beam...
by selecting the 2 0r more flanges..these connection should be created....
how can i do this?
@tinh
@Imoto
Hi
First, find holes on flange, hm_holedetectioninit may help
Second, find mates of each hole
3, bind each hole by rbe2
4, bind 2 rbe2 by beam
*createmark elems 1 all
hm_holedetectionsetentities elems 1
#holes
# hm_holedetectionsetholeparams hole_shape=31
#tubes
hm_holedetectionsettubeparams tube_shape=31 tube_type=0
hm_holedetectionfindholes 1
set n [hm_holedetectiongetnumberofholes]
hm_holedetectionend
using this script ...but not getting single hole...
i am looking for 3D holes...
am i using right script?
Hi @Pandurang
Try this if you already have solid elements created. I am not sure about the parameters though, you can change it
as per your model.
*createmark elems 1 displayed
*findholesinit elems 1 3 30 0 0
*findholessolid 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0
*findholesend
@ tinh....I have made that script its working fine for flange meshing...but now i want to create rbe-beam-rbe connection between colinear holes..
@vipin i know this commands..this only finds out holes..
Thanks for your support guys...
You found holes , so you just bind nodes on the holes by rbe2, and then beam
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
