Mahantesh
Thermal Analysis
Please dont call thermal bc under Load subcase definition for strutural loadstep. Instead apply thermal bc via subcase option TEMP_Load.Also define elastic material property to run through.
Hello Sir,
                Elastic material properties like E and Poisson ratio i assigned in material load col, now the file is running but the results r coming wrong, so kindly guide me is there any other options are there to assign elastic properties
Thanks and regards
Mahantesh
Hello Sir,
                 I am facing the error 1908 while carrying out the simple thermal analysis for simple beam so kindly help us to solve this error and please find the below attached file regarding the problem
Thanks and Regards
Mahantesh T
12.fem
12.out
Hello Sir,
                I  am facing the error 1000 and its showing the temperature error but i have assigned it so still error is coming so kindly help me to solve the error
Thanks and regards
Mahantesh T
Hello Sir,
                        I am facing the error MATi data present, but there is no TABLEMi, kindly guide us to solve this problem
Thanks and regards
Mahantesh T
MATT4: Defines temperature-dependent material properties for the corresponding MAT4 Bulk Data Entry fields via TABLEMi
Use Table create utility to define Temperature dependent conductivity with TABLEM card.
So if you have defined MATT4 under MAT4  card,  call TABLEM card T(K)
