Sign in to follow this
Viking_d
Honeycomb structure meshing
I have a honeycomb structure(image attached below) . The thickness of the walls are 5 mm. It has a length of 660 mm and  height of around 61 mm. I need to mesh it. How do I go about it? Should i mesh it as shell elements? I tried meshing it as a solid, but a lot of elements fail the element check.   What element size is preferable in order to have a good quality index and also how do i decide upon the parameters for the element check?
Any and all help will be greatly appreciated.
Thank you.
On 12/14/2018 at 10:52 AM, vishruthdilip said:
Thank you.
Hi Premanand, I totally overlooked that! Thank you for your reply :)
