Hi francesco aloschi
You can try this:
Go to query panel in Hyperview (marked green), select the component and required outputs you need from the list (marked red)
Then select the simulation step (marked blue) as Mode 1 and click apply. This will give you the outputs in the query window  for mode1.
Similarly change the simulation steps to successive modes and get the outputs in query window.
Once you are done with the required no: of modes, you can click export (marked black) to output the results in query window into an excel format.
Hope it is clear.
Thanks
