Vinivici
Populate a lookup table in Activate
I'm a newbie with Activate (I'm still with the 2017 version) and I'm trying to translate an old model from Portunus in Activate.
My goal is really simple but I don't understand how to do it in Activate.
I have a 3D curve (map response) from Flux I'd like to use in Activate. I've always used a look up table in other softwares but here I really don't understand how to populate it here.
If I try to use a csv of my values, how can I use them with interpolations in my model ?
Hope someone can help me :o)
Thanks !
Hi Vinivici,
The definition of inputs and output looks like this:
  Assuming n=2 (x-axis), m=2 (y-axis), k=2 (z-axis)
    Then output vector with size n*n*k: [f(x1,y1,z1), f(x2,y1,z1), f(x1,y2,z1), f(x2,y2,z1), f(x1,y1,z2), f(x2,y1,z2), f(x1,y2,z2), f(x2,y2,z2)]
Reading of csv and populating inputs and output have to be done as a script in 'Diagram Home Context' or 'Model initialization'.
Best Regards.
Hello RoKet, thanks for the answers !
So you use the 3D look up table to build the n*n*k vector ?
I'll have a look concerning the script part, time to go deaper :o)
Thanks
Yes, I forgot to mention. I check it with this simple model
The script part is sometimes a little bit tricky. Unfortunately I have no example, perhaps someone else can help with a code snippet?
I'm a bit confused here because a lookup table should be populate before and then a given entry will by interpolation have a given result.
Shouldn't the look up table be populated by scripting like you suggested for the csv part ?
EDIT
I think I understand how it worked now :
Look up table is populated directly or through variables given in the Model/Initialization.
Will try to populated based on a csv and the rest should go smoothly (I hope :o) )
Thanks for the help and I hope it can help others.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
