Viking_d
Free edges
I have free edges in my model as shown in the image! It is creating a problem in the mesh generation. Is there anyway I can equivalence the free edges with the adjacent surface?
Hi Ivan,
There is only one edge! Replace- When I select edge on the two opposite faces, it says different edges must be specified. I have tried toggle and suppress as well, it does not seem to work!
@vishruthdilip
you should first imprint the honeycomb free edges on the face plates using geom>surface edit>trim with lines>with lines
and then perform replace edge to get manifold and shared edges:
https://altairuniversity.com/wp-content/uploads/2012/04/Student_Guide_59-71.pdf
Here is the edited model, however it is just a strart and far from perfect
honeycomb.hm
Pranav Hari likes this
On ‎12‎/‎19‎/‎2018 at 9:05 PM, vishruthdilip said:
Hello vishruthdilip ,
You can removw all those free edges in one go. Follow the below steps :
Goem -> Surface_Edit -> trim with surfs/planes ->  self intersecting surfs
Select all the surfaces which you want  and click on trim.
Magic is completed.
Hope it helped.
Brahmadev.
Simon Križnik likes this
I got the next problem: There are some free edges (in red) in the inner part of geometry which generate trouble when meshing.
I've tried Toggle edge, but it doesnt' work right. Could any one help me to solve this problem?
Thanks a lot,
Julio
I'm really grateful for the early and helpful answers you all gave me.
I could finally fix the problem with Geom> surface edit> trim with surfs/planes> self intersecting surfs (select the surfaces) > trim
This "Geom>edge edit>replace" didn't work as the message "Couldn't stitch to the gap" was shown, and the gap was too big. Tutorial was helpful, and i will keep it.
I had also tried  geometry > surface edit > extend, but when extended i was loosing information about the edges (instead of a yellow line, I was obtaining a grey line).
Here I show you the model fixed. Thanks again.
Viking_d likes this
