Pablo I
Error trying to display results.
I made a CFD simulation in Hypermesh using AcuSolve. After running the simulation and trying to display the results according to the video posted at the end, I'm required to select a file. However, no .log files are created as on the video and any of the ones created work. Also, unlike on the tutorial, I'm asked to select a Reader, and I don't know which one to use. Can anybody tell me how to make sure .log files (and any others necessary to display results) are created when running the simulation and which Reader to use?
Can you post a Screenshot of the folder where  you are driving this simulation?
If no.Log file is available, then obviously results cannot be displayed.  If present, HyperView will automatically decide on the reader to use for AcuSolve log file.
Note AcuSolve is an extra installation. HyperMesh only has a user profile for AcuSolve, however without the AcuSolve installation that profile cannot start AcuSolve runs.
Here's the screenshot of the folder. Also, the following error appears and I don't know what it means and how to fix it. Although I'm guessing it's probably related to the other thing :lol:. Thanks in advance.
Based on the 'Job Launcher' the job may be run in the 'C:/Users/pablo/Desktop' directory - unless there is more beyond that.  Can you show the full width of that window to show the full entry for 'Problem directory'?  Above that you showed the 'HYPERMESH.DIR' contents.  Can you also show the contents of the 'Escritorio' directory, one level above that?
