bahadır
WHICH MATERIAL CARDS MUST BE USED FOR 3D PRINTER MATERIALS
On 12/30/2018 at 9:07 PM, bahadır said:
I want to use TPU 95 A (thermoplastic polyurethane) for the analyzes I want to use which material card and its properties should be used for its analysis.
 I m using same material my friend we performed tensile test this material maybe it behave as hyperelastic material
Hi guys !
For the TPU 95 A material, you can model it using MATHE card.
Normally, we perform an optimisation simulation in order to identify the right coefficients (we assume Neo-Hook, Odgen, ... behaviour law). And then for FEM simulation, we use what we identified (in the optimisation procedure) to run for example Tensil Simulation ...
Cheers,
On 12/11/2019 at 4:07 AM, Farouk Maaboudallah said:
Hi guys !
Cheers,
for Poliproplene?
On 12/26/2019 at 6:01 PM, durukanbdilek said:
for Poliproplene?
Yes. You can use elasto-visco-plastic (Hollomon and Norton law or ...)  behaviour law as well.
I joined an example of the modelling procedure.
Cheers,
Lauro-Oudin2003_Article_StaticAndDynamicBehaviourOfAPo.pdf
