Sign in to follow this
Shrinaath
roll bending
hi
i am doing simulation on 3 point roll bending in radioss solver
first step i applied displacement to the top roller in z direction then i applied peripheral velocity to 3 rolls then i stopped the velocity again applied top roller displacement  and given velocity of the roll in different direction.
i am not getting the plastic strain value while the stress i am getting larger than then the yield value material.JPG.d11820e26574acf760d314ed7e691b0f.JPGstress.JPG.5c662edd926962782acfe7510f1760d0.JPGstrain.JPG.a8a826f63510a7de83ecd10c7bfc053d.JPG
the issue is with the stress-strain curve: the first point of yield stress functions (plastic strain vs stress) should have a plastic strain value of zero at yield stress. In your case, the first s-s set should be 0 plastic strain at 152 stress (the second 0.002481 plastic strain at 228 stress and so on), while the linear elastic part is described by E parameter= 190000 (Young's modulus).
Hi ivan
Thanks for your reply i have made the changes for the stress strain curve that 0 strain is at the yield point of the material and the curve progresses as mentioned below. even though i am not getting plastic strain value.
material.JPG.f4946d1fbde6543a0c73d0bce8f1a2d7.JPGstress.thumb.JPG.dba45577fd174689f0d25bf090f90efb.JPGstrain.thumb.JPG.ab0344aa3ae42bd4abcd2c9fcfa40611.JPG
You should subtract the elastic strain (0.000799994) to get only plastic strains. So the table should be:
0 @ 152
0.002481 @ 228
and so on
It is odd the plastic strain is not visible- can you share the model?
Attached is an example of law 36 with plastic strain.
plate_example.hm
Shrinaath likes this
The issue was with solid property parameter Isolid=12, which is an obsolete standard 8-node solid, full integration (no hourglass). Use Isolid =17 (H8C) or 24 (HEPH) instead.
Roll_bending_edit.hm
I have edited stress-strain curve and set up advanced mass scaling to speed up computation.
thank you so much ivan
in 3 roll bending simulation can we do the simulation in stage wise  (i.e) first step the top roller is moved down that boundary condition is specified for this stage and second stage rotation of rolls now boundary condition is differ from first stage
what is multi stage process in hyperform is that helpful for my case?????
i need to consider the spring back also
It is possible to carry out simulation in stages. There are various possibilities:
-most boundary conditions can be switched on/off through Tstart/Tstop parameter
-contacts can also be switched on/off (Tstart/Tstop parameter)
-rigid bodies can be activated or deactivated with a sensor or with the options /RBODY/ON and /RBODY/OFF in the Engine files
-multiple engine files can be defined with different simulation controls
I am not (yet) familiar multi-stage process in Hyperform so I can't comment on that. But given HF uses Radioss solver it should be possible to set up a similar simulation.
Check Example 24 – Spring-back:
http://altairuniversity.com/wp-content/uploads/2012/08/Example_25.pdf
hi ivan
can u explain me briefly about Tstart/Tstop parameter
i need to fully constrain the plate at the specific time i have created constrain for this as in the image is that an appropriate way. when i am running this i am getting the warning as a incompatible kinematic condition and it simulated is get stopped.
thanks
Tstart/Tstop parameters on /BCS card are used for /INTER/TYPE21 mapping, so it will not switch on/off boundary condition.
To release DOFs, you need to use BCSR/TRA, BCSR/ROT engine cards. Please go through following examples, where this functionality is used:
RD-E: 4200 Rubber Ring: Crush and Slide
RD-E: 5501 Fan Blade Rotation Initialization
hi ivan
is type 21 is for shell element in type21 unable to select the slave as brick element
for arresting the dof's i try one method
i created an second engine file to arrest DOF's of the component at a specific time by adding these commands
/BCS/TRA/XYZ
node numbers
simulation get terminated because of mass error
releasing the dof's is fine works well is there any similar way for arresting the dof's
hi @Ivan
i am simulating the manufacturing process 3 roll bending process in radioss, early i used 3D model now i am trying with a  2D model, since plate thickness 3 mm
For that i extracted the midsurface of the plate and assign the thickness of the plate as 3mm. i used P1_shell ishell=24 N=5 thick=3 Istrain=1.
i assigned the material property to roll and plate, boundary condition, contact every thing as same.
shell is bending only in the region inside the rolls, region outside the roll is not bending i have marked in the image .
 does i have used any shell parameters wrongly.
i having problem in imposed velocity also that the rotation of roller. the roller is not rotating in both the direction i have assigned negative sign(-) to change the direction of roller in curve editor.
i have attached my file pls check
thanks
2D_SHELL_0000.rad
2D_SHELL_0001.rad
the region outside the roll is not bending because you had constrained the rotational DOFs of the plate. Only Y translations should be constrained so plate remains centered.
The shell formulation is correct- I would add Ithick=1 so thickness change is taken into account.
Note however the thickness (3mm) to length (10mm) ratio of plate elements is 0.3.
Thick shells are used when thickness to length ratio is between solid and thin shell recommended range:
When h/L is large, shear deformation is at its maximum importance and the user should use solid elements. When h/L is small, transverse shear deformation is not important and thin shell elements are the most effective choice.
The initial downward displacement of the top roller happens in 5ms. Such a rapid loading induces inertial effects, which might be unwanted if you are trying to simulate a quasistatic event.
The negative sign will reverse the rotation- check the model attached. If you have trouble visualizing rotation in HV, use Shaded elements and mesh lines view, hide just one element of roller, contour velocity or show undeformed shape in wireframe mode. Be careful when defining curves; when simulation goes outside the defined range it will extrapolate the slope- in your case the velocities would keep increasing after 155ms.
2D_SHELL_edit_0000.rad
Hi @Ivan
thank you, its clear......
energy error% it is goes on increasing
CYCLE    TIME      TIME-STEP  ELEMENT          ERROR  I-ENERGY    K-ENERGY T  K-ENERGY R  EXT-WORK MAS.ERR
2447500  2985.      0.1239E-02 NODE          27 -89.9%   230.2       9.932       5.925       2448.       0.000
     ANIMATION FILE: 2D_SHELL_A5972 WRITTEN
2448000  2986.      0.1239E-02 NODE          27 -90.0%   229.3       10.88       5.927       2449.       0.000
     ANIMATION FILE: 2D_SHELL_A5973 WRITTEN
     ANIMATION FILE: 2D_SHELL_A5974 WRITTEN
2448500  2987.      0.1239E-02 NODE          27 -90.0%   228.4       11.67       5.930       2450.       0.000
     ANIMATION FILE: 2D_SHELL_A5975 WRITTEN
2449000  2987.      0.1239E-02 NODE          27 -90.0%   227.7       12.38       5.935       2450.       0.000
     ANIMATION FILE: 2D_SHELL_A5976 WRITTEN
2449500  2988.      0.1239E-02 NODE          27 -90.0%   227.0       12.98       5.919       2451.       0.000
     ANIMATION FILE: 2D_SHELL_A5977 WRITTEN
i didn't specify any mass scaling /DT/NODA/CST or /DT/AMS
Negative Energy Error represents energy dissipated from the system and this can be from many sources including plastic deformation and Hourglass energy.
If you have included coefficient of friction then the energy error is due to coefficient of friction which is justified. If this amount of energy error is there when no coefficient of friction is defined, then it may be a case of penetration which is problematic.
The vibrations are due to loading being applied using step (jagged) functions. If we differentiate the displacement and velocity functions we get high accelerations leading to large forces and vibrations. To avoid vibrations the functions should be smooth and/or Dynamic relaxation (/DYREL) or Rayleigh damping (/DAMP) could be used.
hi @ivan
thanks for your reply.
In Rayleigh damping (/DAMP) how to find the values of alpha & beta.
And if i apply the values for alpha and beta means the time step which i imposed through Advance Mass Scaling (/AMS) is not taken into consideration.The simulation runs on with the actual time step... What is the reason behind this issue.
The Rayleigh damping coefficients can be obtained experimentally or calculated (see attached) However, in practical applications they are estimated and adjusted based on engineering intuition. I got good results on some models using Beta=10 and leaving Alpha blank. Rayleigh damping will reduce the timestep so adjust timestep controls accordingly.
http://ejge.com/2003/Ppr0318/Ppr0318.pdf
https://www.researchgate.net/post/Any_suggestions_on_Rayleigh_damping_coefficients
Analysis and Model Description.pdf
hi @Ivan
i will do some iteration on this Rayleigh damping coefficient and lets u know if i had any difficulties.....
i having doubt in the spring back i used the implicit spring back option as mentioned in the example 25 but my results are not that much correlating .
In implicit spring back what kind of solver should we use in tutorial it mentioned /IMPL/SOLVER/2 but in the file which is mentioned in the tutorial DBEND_44 they mentioned /IMPL/SOLVER/1
i have attached the tutorial and file from tutorial for reference.
DBEND_44_0002.rad
you should first smooth the loading functions and only then reduce any remaining vibrations with damping.
I don't have enough experience with implicit spring back to be able to give useful advice.
