Sign in to follow this
Shrinaath
roll bending
Springback results are sensitive to the magnitude of damping factor, especially when unphysically high damping is used.
Check the following papers for details:
https://www.sciencedirect.com/science/article/pii/S0924013604003577
https://www.sciencedirect.com/science/article/pii/S1000936113001751
Hi @Ivan
i facing problem during running the job that my simulation remaining time is keep on increasing with error percentage. i attached the text file ERROR.txt for reference. does the model have any issue in the contact??
i have attached my model file please check
2D_SHELL_0000.rad
2D_SHELL_0001.rad
2D_SHELL_0002.rad
Looks like the contacts are causing the large negative energy error. But the root cause is the too high timestep imposed by AMS. First, run with DT/NODA mass scaling until you get reasonable negative energy (15%) and mass error (2%) throughout the simulation. Then set up the AMS run trying to hit the energy error % of DT/NODA run (as well as stress and displacements). Set the Iflag=2 and Nprint=1000 to output the number of iterations before the convergence of the conjugate gradient in the out file (less than 30 is good). There should be only a few cycles where INTER is controlling the timestep.
It is recommended to use Iform=2 with contact friction.
