Korosh
Can Analysis without change Offset
Hi
Suppose, for side crush of a car, after performing the analysis(Create mesh, define MAT, Prop, Contact ,.....  I will Decide to change the thickness of some sheet's, so , I should define offset for Sheet's that have a change in thickness and then i should change some parameter's such as Contact, Spot weld , ....
Therefor, in analyzing a car that includes many hundreds of mesh, These changes will be very time consuming and costly.
Is there a good solution in this regard?
It is time consuming when you go for each part. Unfortunately there is no other option available in HM or HC.
The only way is to create a script for this. With customization you can do these steps very easily.
Best Regards,
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
