Sign in to follow this
Sushanth
"Create RBE2 Spider" tab not active in Motionview student version 2017.2
I am trying to create a flexible lower control arm using the FlexPrep utility tool in 2017.2 student version. I am facing the following issues:
1. "Create RBE2 Spider" tab not active, hence I am not able to switch to HyperMesh to create a RBE2 spider whose center is one of the interface nodes.
2. As a workaround, I manually created the RBE2 spider in OptiStruct and exported the solver deck as a *.fem file. When I try to use this file for creating a flexbody. I am getting an error.
I have pasted a snapshot of the flex prep utility and the error message when I try to generate the flexbody below. I have also attached the *.fem file and *.out file
Please take a look and let me know how this issue can be resolved.
sla_flex_left_RBE2_created.fem
sla_flex_left.out
Hello Sushanth,
The issue with the Tab is probably a limitation in the Student Version.
Your workaround is correct. But you didn't assign any property/material to the flex body component, that is why you got an error.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
