Sign in to follow this
mabefa
Solid map
Hi, in solid map if I want to mesh a single component and I select one volume under the voice volume to mesh I can choose between surfs and solid. Which is the diffrence between these choices?
the difference is surfs allows to choose surfaces that enclose a volume. In other words, even if a solid is not created, Hypermesh will recognize if a set of surfaces contains a closed volume. In this way, the creation of solid from surfaces (see attached image) is not necessary to carry out solid map.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
