Sign in to follow this
anderlanza
master node in rigid bodies
There are no visible rigid bodies- you should first make them visible in by right-click rigid bodies in browser>view options>show. It will only accept master/independent node of a rigid body.
To constrain in all dirctions except X translation choose appropriate DOF (se attached image). You can also define a skew frame, if you want to constrain in different coordinate system than global coordinate system which is default.
The light green spider is a rigid body and the master node is at its center. Hide all components so only rigid bodies are displayed and then pick the node in the center.
Or right-click the rigid body in the browser and select cross reference. /NODE ID is the master/independent node number of a rigid body. This ID can be entered as Add Node IDs in boundary condition Support parameter.
More on creating,modifying and checking  rigid bodies:
https://www.sharcnet.ca/Software/Hyperworks/help/hc/hc.htm?hc_mesh_rbody.htm
Please go through free Radioss ebook to get started in explicit simulation.
Also check following youtube channels:
Altair University. Altair India Student Contest. ELEATION By Apoorv Bapat
Hypercrash manuals:
HW13-HyperCrash_Training_201702.pdf
HyperCrash_Introduction_12.pdf
