Sign in to follow this
Jan Grasmannsdorf
Generate Points in 3D / Export Mesh
Dear Mr./Ms. currently, I am looking for a way to generate points (in 3D) over a random surface. So far I see some very impressive futures in HyperMash. I wonder if there is an opportunity to export the points that are generated with the mesh. Ideally, i would be able to generate a mesh and then export the points to CATIA V5 where I can use them.
you can export any mesh point coordinates by using the File -> Export -> Solver Deck function in HyperMesh. Please make sure that you choose a user profile (at the start of HyperMesh) and format that is supported by Catia V5. Then you should be able to import the HyperMesh generated data into your CAD system.
 Jan
