I am facing problem in creating bolt pretension on 1D and 3D elements.
I want know all different ways to create bolts and pretension load for the same.
Regards
the best way is to use Pretension manager
27acbc80546bca3176547bcc521a68bc0e7be29d.jpg?image_play_button_size=2x&image_crop_resized=960x540&image_play_button=1&image_play_button_color=54bbffe0
Pretension Manager - Altair University
check the following examples and tutorials:
OS-T: 1390 Pretentioned Bolt Analysis of an IC Engine Cylinder Head, Gasket and Engine Block System
OS-E: 0015 Pretension Analysis using Gasket Material
OS-E: 0140 Pretension Analysis of Piston
Dragon_heart likes this
Hi All,
I am doing a Investigation on a bolted joint in Abaqus.
I have applied bolt pretension in One Load step and applied some external load on the next step.
The steps are continuous an I have requested the section forces as output.
As a result, I have section force in bolt equal to the applied pretension Force in first Load step. This is Okay.
But, even on the end of second Load step, the section force remains the same which is almost equal to the Pretension value.
On the other hand, the stress in the bolt is increasing. Does anyone have any idea regarding this?
Thanks.
