tehran
Remesh around rotaiting part
I faced a problem in 3D flux simulation
when I define an air region between the fixed part and rotating part as compressible I face the below error
Remeshing of Mecha. Sets impossible on the current time step
Remeshing of Mecha. Sets impossible on the previous time step
before solve i cheeked physics and there is no problem and all thing is ok.
please guide me.
regards
22 hours ago, Flux support said:
You will find attached a link to see how to use the compressible in Flux:
file:///C:/Program%20Files/Altair/2018/Flux/Flux/Help/Flux/english/Website/index.html?GeometrieEtMaillageAvecZoneDairCompressible3D
If the problem persist, send us your Flux project.
Best regards.
Hello
I acted as a guide, but there is still that problem So I have sent the file to you in the attachment.
Best Regards.
AFlux.FLU.rar
With periodicity, it is forbidden to use compressible mechanical set. Please remove it, and assign the AIRGAB region either to ROTOR or STATOR mechanical set..
Note that it is better to have 2 layers in the airgap, one belonging to ROTOR mechanical set, and one belonging to STATOR. Please have a look at the way it is done in our demo case given with Flux supervisor (for instance Brushless IPM motor (embedded magnets).
It is surprising that the rotor is fully circular. It seems that the geometry is not fully done. You should define the rotor as solid cnductor to get a torque.
I hope it will help.
On 2/3/2019 at 11:59 PM, lombard said:
thanks for your help
