Jouher
Provide right click option to hwtk component table cell
From HM14, a menu is attached to table cell as default, but to show it, use option -cellmenucommand
You have to provide a tcl proc (not menu name)
Purpose of that proc is to customize the cell menu (already created as default, you don't need to create it)
That proc accepts %M as argument to refer cell menu name, then you can use it to add or remove menu commands suitable with each cell type
Example
hwtk::table .myTable -cellmenucommand {p_PrepareMenu %M %C}
.myTable columncreate name -text name
.myTable columncreate id -text id
.myTable rowinsert end row1 -values {name comp1 id 1001}
.myTable rowinsert end row2 -values {name comp2 id 3000}
proc p_PrepareMenu {mnu column} {
   $mnu delete 0 end
   switch -- $column {
         name {
              $mnu add command -label Rename
         id {
              $mnu add command -label Renumber
As I see, when creating hwtk table, option -menu will attach a menu with event "right click" on header of column 0
When creating a column, option -headermenu will attach a menu with event "right click" on header of that column.
vipin likes this
Because it's a hwtk menu, sub commands "delete" and "add" are changed to methods "clear" and "item"
   $mnu clear
   switch -- $column {
         name {
              $mnu item Rename -caption Rename -command {puts "write a proc to rename comp"}
         id {
              $mnu item Renumber -caption Renumber -command {puts "write a proc to renumber comp"}
