First time using HyperMesh and I am following a tutorial for topology optimisation.
The tutorial I am following is on pages 25-36 in the link provided. When I click OptiStruct, I do not get a message. When I click view.out, I get a message saying: '.out file does not exist.' Where am I going wrong?
OptiStruct_11.0_Tutorials_(1).pdf
Laurence
Thanks for the updated fem deck. I attempted to run the file using Optistruct and I am still not getting an output file. When I view in Hyperview I get the error message: "Failed to attach results."
These are the options I am selecting:
export options: all
run options: check
memory options: memory default.
Any more ideas why it isn't working?
Run option should be set to optimization.Check will start a check run regardless of what is specified in the model. So please set the run option to optimization and run .
